Bad input shaft bearing in the transmission and a bad pilot shaft bearing.
The question could be which went first and caused the other to follow, but it doesn't really matter because you will replace both.
While you have everything out, replace the throw out bearing and decide if it's time to replace the clutch. You are going to have it out anyway.
