Another thing to consider is the type of brake fluid, I believe the silicon .5 fluid can cause brake lines to swell. When the brakes are applied the pressure is forced thru the swollen lines but cannot return.
I use .3 synthetic, thats what your system was designed to use.
A shop is where you wash your hands before you pee.
