9 members (Otto Skorzeny, Cosmo, RAC1812, cmayna, GRNHydra, HandyAndy, Peggy M, 1955 1 Series, 1 invisible),
144
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | anything inside that needs a ground can/will be connected to the dash or firewall, the ground on the inner fender should be out to the the headlights, maybe you can't get the headlights to work cuz there's no ground to the bulbs? .... don't know what switch you have [maybe incorrect?], but the TF switch instruction is date 1954, might help? the dash lights connect toward the front of the switch to get power from the rotary resistor, and the headlight terminal should be labeled "H" Bill | | | |
Entire Thread
Two wiring questions, 54
| StephenB | 06/09/2014 8:13 PM |
Re: Two wiring questions, 54
| Flxible | 06/09/2014 9:11 PM |
| StephenB | 06/11/2014 6:47 PM |
| StephenB | 06/15/2014 10:52 PM |
| Flxible | 06/16/2014 12:28 AM |
| StephenB | 06/18/2014 3:47 PM |
| Flxible | 06/18/2014 4:27 PM |
| StephenB | 06/19/2014 8:18 PM |
| Flxible | 06/19/2014 8:37 PM |
| StephenB | 06/20/2014 12:52 AM |
| tclederman | 06/20/2014 1:12 AM |
| StephenB | 06/20/2014 8:39 PM |
| StephenB | 06/20/2014 8:32 PM | |
