1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Pretty much have things figured out except for two loose ends. I can't find the right spot for the headlight wire. My light switch is different from the picture in the 54 manual in that there are two fused posts on the driver side of the switch and I have a wire from the lights running into the dash that is not connected and none of the posts seem to be correct. All other lights work, so where does it go? Also, I have a ground wire attached to the fender that goes through the dash but I don't know what it connects to. Is there anything under dash (heater, lights, turn signal switch) that requires a separate ground wire? | | | |
Entire Thread
Two wiring questions, 54
| StephenB | 06/09/2014 8:13 PM |
Re: Two wiring questions, 54
| Flxible | 06/09/2014 9:11 PM |
| StephenB | 06/11/2014 6:47 PM |
| StephenB | 06/15/2014 10:52 PM |
| Flxible | 06/16/2014 12:28 AM |
| StephenB | 06/18/2014 3:47 PM |
| Flxible | 06/18/2014 4:27 PM |
| StephenB | 06/19/2014 8:18 PM |
| Flxible | 06/19/2014 8:37 PM |
| StephenB | 06/20/2014 12:52 AM |
| tclederman | 06/20/2014 1:12 AM |
| StephenB | 06/20/2014 8:39 PM |
| StephenB | 06/20/2014 8:32 PM | |
