Ok, so by "switched" you mean the ignition? Then the power wire goes from Alt to Amm and out to ignition. the blue wire from alt goes to ignition and out to coil.
While weeding out some old wires I found a ground wire connected to wheel well but not connected on the other end. It is long enough to reach dash so I'm thinking it must go to the lights???
