| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have seen a number of Okies leak around the outside. It is best to put some sealer on the OD during assembly.
As long as you keep the same shims in front of the front pinion bearing the only set-up you will need to do during assembly is set the ring gear back lash.
See the USA in your vintage Chevrolet! My Blog | | |
