Have you figured out exactly where the leak is occuring?
If you don't already have a Steele rubber gasket in there I would get one, and cement the gasket in on the body side. Then look for the dent or creased spot where it is leaking, and fix it. The windshield probably isn't setting flat against the seal.
Paint & Body Shop moderator
