| | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GM used the 10 hole Motor Wheel hub for a long time after 55 and not all of them were the the the Firestone design. 6 Hole stud piloted was an option. Many of the were the Goodyear design had a lock ring and there was also a 3 piece design. These wheels will take either a 7.50 or 8.25 x 20 tire which is readily available in the US. There are a lot of old GM bobtails in barns in the Dakotas. I don't know if there are are still any border crossings there with no customs. I haven't been there in quite a while. Quite often a whole bob tail field truck with 6 servicable wheels can be bought for less than $1,000 and the cab will fit a pickup. | | |
