If the side covers are 6gh it is a 292. 65 may have been the first year for the 250. Pull a plug and check to the pistons, flat top pistons 230, dished piston 230. Check the engine code on the distributor pad. It will tel eng, model, trans, problem is finding a decoder. Hope that helps.
Larry
I don't own a vehicle that isn't old enough to drink.
