| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 54 pickup sending unit installs in the top of the tank, there is no way to install it from the bottom .... remove the wire[s] from the sender, remove the screws, pull the old sender out, replace with the new one, reinstall screws and wires, the wire from the post terminal is to the gauge, good idea to check the continuity with an ohmeter - and it's usually a good idea to have a wire from one of the mounting screws to cab ground to insure the sender is getting a good ground Bill | | | |
Entire Thread
Gastank sending unit install, 54 1/2 ton
| StephenB | 05/25/2014 12:03 AM |
Re: Gastank sending unit install, 54 1/2 ton
| Flxible | 05/25/2014 12:31 AM |
| 52Carl | 05/25/2014 4:14 AM |
| StephenB | 05/27/2014 8:23 PM |
| 52Carl | 05/28/2014 4:04 AM |
| StephenB | 05/28/2014 4:03 PM |
| Flxible | 05/28/2014 6:57 PM |
| Old GMC Gold | 05/28/2014 11:30 PM |
| StephenB | 05/29/2014 10:33 PM |
| DADS50 | 05/29/2014 11:44 PM |
| StephenB | 05/31/2014 7:55 PM |
| DADS50 | 05/31/2014 8:25 PM | |
