| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Wear on the bottom is a sign that the bell was not adjusted correctly and only wore on the bottom. If the bell is reset correctly there is a good chance it will work fine. Here is the adjustment process. National seal company use make a brass insert that fit on the back of a transmission that gave you a new surface for the bell to seat against. I find them at swap meets on occasion.
See the USA in your vintage Chevrolet! My Blog | | |
