| | | Forums66 Topics128,271 Posts1,058,412 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | glamis4X4,
The 6 six volt batteries in series would give you twelve volts. I have read that in this application, both batteries must be matched in amp/hour capacity. Although not scarce, if one were to fail, finding a duplicate might take some legwork.
Two 12 volt batteries in parallel would give you twice the current capacity of a single battery. Wouldn't this be the most desirable for a travel trailer situation...especially if you have a bunch of hungry accessories on board.
I don't fully understand these theories, so this could be bum info. My thought would be to go with whatever the manufacturer put in the trailer originally.
Stuart | | |
