thanks Steve; it has a 30 psi gauge and it does tend to run at those pressures you mentioned except during the summer months it may be a little lower. I'm age 67 so it's range is within 10 miles of home on country roads at speeds of 25-40. strangely enough that is where the truck and I are the most comfortable. in the gallery under pete black.
