| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Dennis, It's probably unlikely without a massive amount of work. The Columbia unit is part of the rear differential which has it's own torque tube and a completely different rear spring and suspension configuration. There would be another issue mating the torque tube to the transmission and of course different rear brakes and wheel bolt pattern. It also has control components and a vacuum unit to make the gear change. Columbia components are becoming rare and are priced accordingly. Change out the rear end and I'll build you an overdrive. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
