Wow, Okay.
I'm glad you guys where here to field that one. I not only have a sender on the water pump and intake manifold, but also a 1/8th line coming up from behind the dist. cap. I wasn't sure what that was and wasn't too concerned since it wasn't leaking anything. I’ll clean this up and pick up the electronic senders for the new gauge cluster.
On a side note, I consider myself more of a body man then a mechanic (obviously). As I get more involved with the engine I'll be leaning on the experts here for guidance. Though, I shouldn't need to in the immediate future as this power house seems to be in great shape (mechanically) smile
Thanks again guys! I truly appreciate your help.
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
