1 members (baldeagle),
27
2
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hook the bat. cable to the big post naturally. The purple wire is the start wire from the ign. switch or neutral switch. It will hook to the small term. on the solenoid. The other wire is a resister bypass. If you are using HEI you don't need it. If you are using points you may get by without it. You can use a Ford type solenoid as a relay & get the bypass off it. Some ign. switches have a term on them for bypass. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
