7 members (DoubleB, G508, Peggy M, Bill Hanlon, Otto Skorzeny, TUTS 59, 1 invisible),
200
7
Mod | | | Forums66 Topics128,283 Posts1,058,517 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | The three brush system doesn't use a voltage regulator..but merely a voltage cutout relay. If a 8 volt battery were installed, wouldn't the field windings have higher voltage available to them, which in turn would allow the generator to produce a higher voltage.
The system is so primative that maybe it can be regulated by the voltage of the battery. Does this theory hold any water?
Stuart | | |
