3 members (Otto Skorzeny, Gdads51, 1 invisible),
137
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Not sure about a 1960, but if you measure your old axle, you can find widths of 9" if you google around. Width is one thing, then other is spring perch location, but those can be cut and re-welded. Emergency cables and brake lines should be pretty simple retrofit. See sites like: http://www.therangerstation.com/tech_library/9InchAxles.shtml
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
