| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 37 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 37 | My old tattersfield intake came to me with two Rochester’s. One of the carbs has a broken idle adjust screw in the throttle body that is not fixable. The setup is for a 216 that I’m putting on a 235. I have read that I need to use matched carbs and these Rochester’s are in nice shape for a rebuild. What makes them matched? Can I just change the throttle body? The # on the base of the throttle body reads 7004522c on both carbs. I’m guessing that I need to find that same # of throttle body. Carb body reads RF Rochester GM | | |
