| | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | One issue at a time, Washer between the distributor and block? Big flat washer looking thing? I am not sure what you have. Cast drive gear on a forged cam will wear fast. Forged gear with a cast cam will rear the cam also fast. Match the drive gear to the cam. Which distributor you have can be determined by the number on the label on the side of the dizzy. There is a Good post on the dizzy part numbers on here some where. I just can't remember where.
Steve H
