I have an electric fan mounted on the outside ( grille side ) of my radiator, set up on a thermostat switch set at 190F. Currently it is pulling air thru the rad and out the grille. This seems at cross purposes with standard fan which is pulling in the opposite direction ? Is there a way to reverse the electric fan wiring to push, or are the blades 1 direction only ?
Thanks
1940 Chevy KC 1/2-Ton
