I am getting ready to remove the cab from my 46 chevy 3/4 ton and would like to unfasten the steering mast from the gear housing. Is there an easy way other than taking off the gear box from the frame and removing pitman arms and the other related stuff. I can fiddle with the gear box and linkage later as I merely want to get the steering wheel and it's shaft our of my way so I can unbolt the cab and remove it to a dolly.
thanks,
lane
sweetpealane
