3 members (Hotrod Lincoln, BC59, 1 invisible),
155
0
Mod | | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | The shifter problem seems to be OK now. I swapped out the shift rods and I put a spring inside the transmission bellcrank and shimmed it up so it wouldn't be so sloppy. I am not sure which actually did the fix but its good now :-)
Joe
1955 First Series 3100
