48loadmasterguy,
The rig at work with roof lights has a ground wire connected in series between all the lights, and travels down a pillar along with the power wire. This ground wire is then attached to a small machine screw on the dashboard. This would involve removing the headliner to access a mounting bolt (ground) on each light.
Stuart
