Quote
Originally posted by Tiny:
Normal. Everything is feeding off of the alternator when the engine is running. The battery is basically out of the loop unless there's a load the alternator can't meet.
yep. Don't make a practice out of it as you could fry some alternator wires.
"It ain't a truck if you can't hose out the cab."
