Originally Posted by Steve_H
I don't see one in the stock setup
Look at items 11 and 12 in the master cylinder cutaway. That's a built-in residual valve that keeps about 10 PSI pressure in the brake lines to avoid drawing air past the wheel cylinder cups. The tension of the brake shoe return springs keep the brakes from dragging the drums. Disc brakes can only tolerate abour 2 PSI of residual pressure because there are no return springs for the caliper pistons and the pistons are much larger diameter than drum brake wheel cylinders- - - -more push on the brake pads per PSI of line pressure.
