| | | Forums66 Topics128,120 Posts1,056,649 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | You can put an electric pump and pressure regulator on. You will need to block the pump mount with a gasket and plate. But what you most likely have are some leaky vale and seats in the carbs. The fuel should not leak from the float bowels. You might have a pump with bad check valves that allows the fuel to flow back into the tank. But that would only happen if the tank is lower than the pump. Check valve is available. Here is one source. http://www.oreillyauto.com/site/c/detail/RUS0/650603/N0284.oap?keyword=check+valve
Steve H
