| | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Your 1940 master cylinder and clutch and brake pedals mounted to the side of the transmission and to the bellhousing. You will need to get creative to use that transmission. I have on several occasions used the pedal/ master cylinder mount from a 1948-54 PU on one of these earlier trucks. The 1948-54 set-up mounts to the frame. This allows you to use any transmission. Others here may have more ideas.
See the USA in your vintage Chevrolet! My Blog | | |
