| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely, yes. You'd have "too much carburetor" if you use two carburetor rated for that year (or newer) 235. Will you be using dual exhaust manifolds?
Before you buy 216 carbs (such as Carter or Rochester), check the bolt-to-bolt distance for the carburetor mounting bolts on the intake. All 216 and early 235 carbs have different/smaller bolt spacing than newer 235 intake spacing.
