| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As said, there is a hole to put a long bolt in to hold rod up while installing pump, then replace with short bolt. They never needed any sealer in my experience, wouldn't hurt probably. A copper washer will work if you don't like sealer in there. Post picture of other leaker? Are you sure both leak or just one and spilling onto other? I think you will find the bottom hole is blind. You will find that when you put in a short 3/8 bolt in the top hole, the leak will go away as stated by Don and Jerry.
"These same holes in my other truck aren't plugged and never leaked"... ????????what engine? What year? is it FI? Better double check that!!
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
