3 members (Shardean, Joe H, 1 invisible),
89
2
Mod | | | Forums66 Topics128,057 Posts1,055,814 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | WCKaner,
I will go out on a electrical limb on this one. Does your '66 C10 have a printed circuit board dash panel...I think it does! I wonder if turning on the headlights bleeds power through one of the little dash lights and 'cornfuses' the ability of the fuel gauge to see ground and read correctly. Maybe this short is finding ground through the fuel gauge.
If you sit in the cab at night and pull on the headlights, is there a bulb in the dash that is blown out or appears weak! This could be your issue....maybe. I could get blown out of the water with this theory...lets see what happens.
EDIT. Further digging leads me to believe that your dash panel is a conventional wired system, and that I might be way out to lunch.
Stuart | | |
