| | | Forums66 Topics128,134 Posts1,056,401 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | vonguinness,
If you look in the 'Tech-Tips' at the top of the page, there is a article in the electrical tips on converting a 6 volt generator/voltage regulator system to a 12 volt system using a SI alternator. There are some errors in the tech tip, but it will give you a general idea.
Stuart | | |
