0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | unlike dual carbs, you should set up tri carbs with progressive linkage. Run the engine on the center for the first 1/3 of the engine rpm and then start opening the ends.
Opening 3 carbs at lower rpm's causes very low and inefficient air flow through all the carbs. | | |
