2 members (moparguy, 1 invisible),
113
3
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If the parts in the latch are worn, your handle may not open the latch fully. Mine does this and it sounds like yours is doing the same but more severe. Can you see which part is causing the issue and if you can bend or adjust anything? | | |
