| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | The outside handle has a square shaft that goes into the latch assembly. There is pin in that handle that holds the shaft. That could be sheared. If the handle is keyed it is more complicated. The pin holds the square shaft plus all the lock parts. I have a couple of pictures in photo bucket. | | |
