| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Many countries have banned Cad plating. The U.S. banned it then removed the ban with restrictions regarding chemical usage and disposal. Therefore cad is now expensive and the replacement is Zinc chromate. Most hardware stores will have the zinc coating on their carbon steel hardware. Which is OK for your truck, looks good and is the low price you desire.(grade 5). Aircraft industry still uses Cad plated (Mil Spec) on non stainless hardware because it is much better for their requirements. If a supplier has Cad plated, it could be 5X higher +. Don't think you want galvanized, up to you.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
