7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 11 New Guy | | New Guy Joined: Apr 2008 Posts: 11 | Hi I am upgrading a 54 1/2ton to a dual master cylinder. I am also replacing some other stuff along the way. I am having trouble finding fittings. I am trying to find replacement fittings for the rear brake cylinders. I don't think I can get the old block fittings so I am looking at using a banjo fitting. Has anyone done something similar? Is there a good place to find these things. An internet search wasn't all that helpful. I am pretty sure that I can replace the wheel cylinder with a '55 and on which, I believe, will fit and uses a direct double flare into the cylinder. But only if I can't find anything else.
Thanks John | | |
