3 members (Hotrod Lincoln, BC59, 1 invisible),
155
0
Mod | | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey, Should just be two bolts holding the master cylinder to the drivers side of the frame. Carefully take the brake line off the back then disconnect the front linkage. As you disassemble the cylinder, just lay out the pieces as they come out. It's pretty simple to do just take your time and keep everything clean. You will probably have to get a brake cylinder hone and and hone the inside of the master cylinder. If it's pitted badly, you will need to have it bored out and sleeved or find a different one.
Bruce | | |
