I bought the CCP 400 (toyota) steering kit the other day. I need to buy a column in the near future.
I want to use the flaming river roaster column,(i'm thinking 28")
http://www.flamingriver.com/index.php/products/c0002/s0008/FR21022-28BK but want to be sure before I spend the $500. on a column.
What did you guys use with the Toyota/CCP 400 box install?
If you used the original column, how long is it? When you cut the lower section,how much is sticking out from the firewall to the box?
Thanks Jeff
