I have googled this for hours.
I have a generic 7 wire turn signal switch that came with one of my trucks.
No wiring diagram.
I have taken it apart and figured out how it works.
Orange and Red go to flasher
Blue and Green are front and rear
Black and Cyan are front and rear
yellow is directly to the green light on the tip of the flasher
This one does not have emergency flashers.
I think this is the same one.
http://www.ebay.com/itm/1-TURN-AND-...080-/200674485234?_trksid=p2054897.l4275
I think I understand how to wire up the switch.
Im hung up on the tail lights.
Im using a 32 ford style tail lights with two wires.
one for stop, and one for running lights.
Green = running
Black = Stop
How do I tie the brake lights and the flashers together.
If I run a wire from the brake switch to the black on the tail light
I will have stop lights. They will be lit rather turn signal is on or off.
So, it seems one of the wires on this turn signal switch should be tied into the stop lights.
The orange and red?
The orange is one side and red is the other side.
These have to go to the flasher, if they do not one side wont get power.
Strangely this is a 6 wire and not a 7 wire.
The yellow wire goes straight to the green light on the tip.
It is not connected to the switch in any way.
Anyone have any ideas?
