Hi, I need to pull and replace the carrier bearing, once the rear section of the shaft is out, how do I remove the yoke in the middle, to remove the carrier and replace the bearing? it appears to be a spline sleeve but my manual makes it appear there is a threaded connecter also? can anyone explain it? so I don't ruin it
thanks
