0 members (),
196
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | After adding on the common turn signal setup to my truck with mixed bulbs....fronts conventional and rear LED's, I found my emergency flashers wouldn't work although the turn signals functioned properly. I was using the "3 prong electronic" flasher. Changed back to a conventional 3 prong flasher and they all work as advertised.
Hope this helps someone avoid the same problem.
Dave | | |
