| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | The wire from the coil to the distributor is what triggers the coil to fire every time the points break. Without it, you've got a piece of yard art, not a truck. It will never start!
The capacitors (condensers) are not necessary, except for the one inside the distributor. The ones at the ballast resistor, the voltage regulator, and the generator armature connection are noise suppressors for an AM radio. Jerry
