I don't think it is a good idea to even momentarily shove a couple of hundred amps across a thirty amp ammeter. I would wire the + side of the ammeter to the positive battery post and a grounded horn, headlight or heater motor, etc. to the - ammeter terminal. Or you could put a battery charger set at low current across it.
