1 members (Steelonsteel),
141
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Rochester 'B' wasn't released till the '50 model year Curt. You must have a later 235 in your truck. That power piston is a critical part to the performance of that carburetor on your engine and is held to a fairly close fit since it's a vacuum operated device. I don't see anything wrong with that one from the angle that it's shot at. Just be carful when cleaning it, you don't want to reduce the clearance and it must be straight as it pushes the ball off it's seat.
DG
Denny G Sandwich, IL
