| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | They were supposed to be straight. It is easy enough to run the front axle into something (stumps are a [censored]).
If you paid for a good one, take it back.
A small amount will be corrected for with toe in, but you have to be really sure it doesn't have a twist.
To check, put a straight, tight fitting rod at least 3 feet long in each of the kingpin hole. Make sure they are absolutely parallel. | | |
