1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Swelling the seals to prevent a leak is a common patch. I'd say that it really doesn't fix anything, as you're still leaking oil.
Depending on the reason for the leak (old seals, a groove worn on the sealing surface etc) swelling of the seals may not do much.
Not sure if a 49 would have the rope seal or newer neoprene type. My 42 was rebuilt with rope seals but that can also affect the swelling action.
I would consider 1qt every 200 miles a serious enough leak to fix ASAP. Seals are like $20 and doing the front and rear seals on a 216 is something you can do without taking the motor out. Your driveway must look like a BP oil spill.
Entire Thread
Engine snakeoil,
| Volfandt | 02/17/2014 1:42 AM |
Re: Engine snakeoil,
| 52Carl | 02/17/2014 2:00 AM |
| Ed Hotaling | 02/17/2014 2:06 AM |
| Achipmunk | 02/17/2014 2:45 AM |
| pfarber | 02/17/2014 1:49 PM |
| 52Carl | 02/18/2014 4:38 AM |
| Volfandt | 02/18/2014 11:31 PM |
| 52Carl | 02/19/2014 2:57 AM |
| PaPa Joe | 02/21/2018 6:22 PM |
| tclederman | 02/21/2018 9:27 PM |
| Dragsix | 02/21/2018 6:44 PM |
| Hotrod Lincoln | 02/21/2018 9:23 PM | |
