8 members (55shaker, Ridgeback, Peggy M, Gray_Ghost, NJC, 3B, Bucker, 1 invisible),
88
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | I like to flush brake lines with alcohol. Get a gallon of methanol (shellac thinner) at the local hardware store or big box store like Home Depot and pump a quart or two through the system with the master cylinder. Then follow with at least a pint of fresh brake fluid, and bleed the brakes as you normally would. Never, EVER put a petroleum-based solvent into a brake system! The residue will destroy rubber parts. Alcohol and rubber brake parts are pretty compatible, and any leftover alky will evaporate. Jerry
