2 members (Tstan7, Napco Mark),
75
6
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I went the other direction and got a smallish one. Honda EU2000i. This is for house backup. I put in a transfer box last spring so it is easy to just plug it in then switch on whichever circuits I want to use. Luckily I haven't needed it, so can't give any report on how it works over time. It will run everything in the house except 220v stuff. I have 10 circuits so I can choose what combination of things to run. I wanted something quiet that only sipped the gas. As stated above, you have to do the math on what you want to run simultaneously.
Dennis
40 Chevy 1/2 ton
