Classic Parts part number is 52-024. The high beam wire color is red whereas the instrument lighting wires are gray. So, yes, I found the high beam socket (was including the high beam when I mentioned 6 sockets on my original harness).
I called Classic and they told me that the key switch light is not needed and thus not included in the harness. who are they to decide that (other than who builds the harness so I guess they can do what they want). Nowhere in the description of the harness do they mention no switch lamp socket is included. They don't even sell a loose socket so I can splice it in. I will have to salvage one of the originals.
So, what does the ignition switch lamp provide...a glow around the key cylinder so you can find it by pull the light switch to parking lamp position? Or, is it best to not use it at all?
